As per the title, I run a mirroring function against two identical large folders. As the attached three logs show I run the function, it performs updates which takes about 45 minutes then I run it again and it performs almost the same updates again, a few less files each time. None have been modified.
I'm running W10, the target folder is on my wifi connected server (slow response) and I'm running Version 11.5 donation edition, 64 bit, 1/2/2021. Any help would be appreciated.
Mirror Function updates identical source/target folders
Run a compare and hover over the items, it will tell you why it decided to sync them
Thanks for the idea, did just that and found that the "Date Modified" is different on many of the files even though they had just been copied. So FreeSync (great pgm) is off the hook as I did a manual copy of 4 files as one function and after the copy one file had its 'Date modified' date updated to match the source however the other three still had mismatching 'Date Modified' values. Oh well, off to the WD My Cloud forum to find out why copies don't quite work. Thanks again! JA
