Tick and untick "ignore errors" anytime
root
It would be good to be able to enable/disable "ignore errors" anytime (at the two locations where currently a static message is displayed that errors are being ignored).
In which scenarios are you missing this functionality?
DragonFox
i belive it's in the case of:
job1: do not ignore
job2-6,8-10: ignore
job7,11: do not ignore
root
Example scenario:
* Undo an accidental click on "Ignore all"
or:
* Start sync, then it turns out that I have to leave, but want as many files as possible to be synched until I return, i.e. future errors should be ignored.
You'd have to do some kind of interrupt or poll the setting every so often. Are you running into errors that often?
root
Just poll the setting exactly when errors occur. Like currently.
Currently, changing the setting is possible only in one direction and only at specific times. This limitation doesn't make much sense.
I see how that would be helpful, it wouldn't be intrusive either because the icon status is there, as you said.
