Can someone please tell me what the "last session" is for? I delete that and it keeps coming back.
Fall jemand auf deutsch antworten kann, wäre das auch gut. Ich lösche das "Letzte Sitzung" aber es kommt wieder. Brauch das nicht,... bzw. wofür ist das überhaupt?
Last Session / Run
The "last session" configuration is simply the very last synchronization configuration that was run in FFS on that computer. So, even if you did not explicitly save the previous sync configuration under a specific name (e.g. *.ffs_gui), you can still recall and run the last run configuration across FFS sessions.
Ok thank you. I don't need this. Can i disable this?
> Can i disable this?
You can not disable it. It's always there.
Consider it the equivalent of some web-browsers re-opening the web-pages that were open when the previous browser session ended.
Ok thanks again. :-)
