New error in Version 11.6 64-bit for Linux
jcp
Hello FFS. I just upgraded to the latest 11.6 version for Mint Linux 64-bit.
With 11.5 I had not errors using FFS for file backups to my QNAP NAS.
Now it gives a "cannot set directory lock for the following folders:
ENOTSUP: Operation not supported [fchmod]
See the attachment.
I did update the firmware in the QNAP today, so it is possible that the change was caused there.
As a work-around I think I will revert to 11.5. When I fall back to the older version, I will write an update.
Thank you
John Paterson
