Turn off or merge logs by file size.
Currently the application produces a new log file for each sync cycle which over time bloats the file system. Is there any way to turn off logging, or have it append to a single file up until a certain file size before it creates a new one? Any kind of solution to cut down the volume of log files is appreciated.
You can turn off logging in the ffs_batch file creation dialog via a checkbox.
