I have set up two different sync that will start at 21.00 (9.00 PM) and the next at 22.00 (10.00m PM but I get this error message when I check my comtputer the next morning. Anyone knows why I get it?
I have not aborted the task since I was now at my computer.
/Staffan
the action was aborted by the user (0x800704C7)
Scheduled task? Are you able to watch it next time?
Also, what happens if you run the command manually?
If I run it manually it works just fine.
I could change the time to see what happens. Normally I don't sit by the computer when it supposed to start, that's why I set time late in the evening.
What's in the sync logs?
Assuming the Windows Task Scheduler:
In the Task Scheduler you can define a maximum amount of time that a task is allowed to run.
If your one or both of your FFS syncs take longer to run than allowed by the Task Scheduler, that FFS instance will be terminated (aborted) by the Task Scheduler.
