Hello.
I am trying to use a google shared drive to make my backup. I configured and everything is working fine for some time but, suddenly, the windows reboots. It occurs only in the backup from local do google shared drive. Other backups works very fine.
This is not common in my windows. I work for weeks without any problem, but always that I try to make the backup with FFSync local do gdrive (shared drive), windows reboots.
Tks in advance.
Google Drive SYNC reboot the windows
You must have a post-sync command running or have the config set up to reboot windows after completion. Look at the sync settings for that setup
Thank you for the answer. I double checked here, and I am not using this option. And the job it is so far to complete. It is 1tb data, and is rebooting after few GBs.
