[Donation Edition] - Unused Devices
Illioc
Hi all,
I'm using a Donation Edition on 2 Computers (perso + pro).
Last week, I've re-installed Windows + all softwares on both of them.
Now, FFS tells me it's installed on 4 devices.
I went to the page and set the 2 previous installations as "Unused", but it seems it's not enough.
(https://freefilesync.org/thank-you.php?tx=*******************)
What other action is needed to effectively remove them ?
Regards,
Illioc
If I remember correctly, Zenju has said that it won't cause any issues and licenses 'reset' after a FFS update. You shouldn't need to worry about it, marking them unused should be working though.
You can mouse-hover over the recycle bin item to see when they will be removed. Without some kind of delay, counting devices wouldn't make much sense (because FFS doesn't require a permanent internet connection).
Illioc
Ooops sorry, I didn't see the "hint" when mouse-hover.
So they'll be removed on 27/02 and 04/03. Fine !
Thanks ! :)
And keep the good work, you ROCK !!!
