Linux Installer without superuser
gillman
Hey FFS team, thank you for your work on this exceptional software.
It used to be possible to install FFS without root privilege, but with the new .run , this doesn't seem to be the case anymore (other than, I suppose, by building it myself). Do you think this might change in the near future?
Many thanks
bgstack15
The .run file is extractable with 7-zip. (/usr/bin/7z or /usr/bin/7za from p7-zip or p7zip-full), and inside it is a .tar.gz which appears to be the traditional file.
