I am using FFS 11.6 64 Bit 01/02/2021.
I have been uisng FFS to sync through SFTP to my RaspberryPi.
The RaspberryPi is running the latest version of RaspberryPi OS. This has only just started happening, I was able to successfully sync a couple of days ago but now when I run the sync I get the following errors on all of the files I am trying to sync:
15:54:50 Warning Cannot write modification time of "sftp://xxx.xxx.x.xxx/mnt/mediaserver/Music_FLAC/The Black Eyed Peas/folder~bab3.ffs_tmp".
LIBSSH2_ERROR_SFTP_PROTOCOL: SFTP Protocol Error - LIBSSH2_FX_PERMISSION_DENIED [libssh2_sftp_setstat]
The files do sync correctly but each time I run the sync now it says the same files need re-syncing everytime. Thus making it a very slow process.
Is there is anything that I can change to allow FFS to change the file modification time of the temp file?
Up until now FFS has worked brilliantly and not given me any problems, thank you.
Richard
Hi, I have the same warning, is there some fix to this error (FFS 10.24 )
Cannot write modification time of "sftp://x.x.x/parent/son/FiletoTransfer~fce2.ffs_tmp".
What is the reason FFS gives for wanting to re-sync?
Thanks for the reply, things seemed to have settled down. I am still getting the errors when connecting through sftp but on running the compare again I am now only getting the new items listed as needing to sync rather than all of the other previous ones.
My main query is why am I getting these errors in the first place, what has changed to cause this?
I now simply ignore the errors but it does not sit right as I like to know why something is happening.
Thank you.
Thank you.
