So what exactly is considered an error? For example I have my files being synced across the network and if the network connection drops out, it'll say "waiting for connection" but it doesn't seem to throw an error? I would consider this an error because it is not able to sync the files anymore. Basically I want to be alerted when the synchronization process is broken.
Thanks,
Brian
Trying to use "Run a command On Errors" with RealTimeSync
