SD card access
ViliamMajer
Hello.
I'm trying to connect Andriod's phone with Windows 10.
I downloaded https://play.google.com/store/apps/details?id=com.medhaapps.wififtpserver&hl=en&gl=US
Freefilesync connects to the phone, but I only have access to the phone's internal map, not the SD card.
I would like the selected folder on the SD card to be backed up to my PC via WIFI.
Thank you William
Gianni1962
Choose \ in the app settings as mounting point, then you will find your sd card in the storage folder.
ViliamMajer
Toy mean this?
ViliamMajer
So far, only the Internal Memory allows me to.
Gianni1962
Yes, root folder \
Then stop and start the app.
Then scroll down to "storage" and open it.
ViliamMajer
I have only free apk.
ViliamMajer
here you go
Gianni1962
Set Root folder to \ then stop and start the app.
ViliamMajer
I tried it but I can't get to the SD card.
I have no root intervention on the phone.
ViliamMajer
I even tried this application everywhere the same I also enabled in the file browser settings in Android to have network access to other applications It still shows me only the internal memory
Gianni1962
I'm using the free version, the latest version, installed from the Google Play store.
No need to "root" the phone.
When I say Root I mean the app option to set the Root folder, that in your screenshot continue to say "Internal memory" but should say "/".
