Copy always everything
TechnikOnkel
I would like to use FreeFileSync to copy virtual machines from A to B every week.
Currently it only copies VMs that have been "changed".
How can I set that everything is always copied to B?
Task schedule, look into the documentation
TechnikOnkel
Thank you! But this is not what I asked for...
Wait, so you want to copy everything, even if it hasn't changed?
Use robocopy/xcopy then
TechnikOnkel
yes thats right! Can FreeFileSync handle this or just copy changes?
Do you know another GUI Tool for this? Thank you!!
You are better off using task scheduler and using robocopy
You are better off using task scheduler and using robocopy xCSxXenon, 06 Mar 2021, 18:17
Nah! :D The issue is not with FFS, but whatever tool is used for the VM that doesn't properly set modification times. e.g. VMware correctly sets modtime on VM use. If not, there is likely an option to have it behave correctly.
I took it to mean that the timestamps won't change, so FFS won't see it as a sync at all
I took it to mean that the timestamps won't change, so FFS won't see it as a sync at all xCSxXenon, 06 Mar 2021, 18:53
Yes that's correct. My remark was geared towards "not using FFS", when the IMHO better solution is to fix "not saving time stamps", what I consider an issue rather than normal behavior.
