running in the background
zdenekc
I'm trying real time sync. At work, I am interrupted by the constant pop-up of a window. How can I set Free FileSync and RealSync so that their window is in the background?
dynosire
When you save your batch job, put a check in the "Run minimized" checkbox and you're good
zdenekc
Thank's. It works.
