i like to use RTS on an Ubuntu Server to keep two directories (or even more)
always in sync. On the server there is no X-Server installed, so no GUI
possible.
How could i setup RTS here, because i can't find any documentation about the
configuration files for RTS?
Thanks in advance.
Realtimesync on Ubuntu server
First you'll need to find out if it starts at all. Although RTS can skip the
GUI by passing a .ffs_real or .ffs_batch file as command argument it still has
dependencies to GTK2. More information about RTS usage can be found in the
help file.
help file.
ruebedo
you could try setting up iFolder on Ubuntu Server
