Sometimes I need to copy a huge number of small files from one SSD to another. The default copy in Windows is very slow(~30MB/s). The FFS donate version gives me a lot of help. The copying can be very fast(~450MB/s) if I use FFS to copy in 64 threads.
However, the problem is, if I want to copy files (not regular sync or backup, just copy), I have to open FFS, and choose which folder to be copied to and from. It takes a lot of time. If FFS can be integrated into right-click menu, it will be very helpful. Just like TERACOPY.
The parallel copy function in FFS is great. I hope it can take place of my windows copy handle.
Thank you.
Integrate donate version into right-click menu
FFS isn't a copy tool unfortunately, but you can look into registry keys that create a context menu entry and create a command the runs a cmd line FFS setup
