I have reinstalled my Windows 10 computer and have an error for 2 different synchronization tasks depending on the same partition (2 tasks because of 2 backup locations). The error tells:
Impossible de verrouiller les répertoires des dossiers suivants : Impossible d'écrire le fichier "E:\sync.ffs_lock". ERROR_PRIVILEGE_NOT_HELD: Le client ne dispose pas d’un privilège nécessaire. [CreateFile]
It's french and simply tells it can't write the sync.ffs_lock because of privilege.
What should I do?
Thanks.
It seems the user under which credentials FreeFileSync (FFS) is run does not have Write privileges (and possibly not even Read privileges) in E:\
Binome
I have granted total privileges for all users thinking that was the problem but no change.
What could I do?
