Real Time Sync Bug/Error?
gorkatjimmies
Version 11.8 Windows 10 Pro.
I am testing Free File Sync. I have a Real Time Sync set up and everything works. When I add large files, about >=25GB, to the watched folder it starts the sync before the file is copied (after the number of seconds to wait has passed). It produces the following error.
I have tried to shorten and extend the number of seconds to wait but it still kicks off the sync long before the file is copied. I don't want to interact with the user interface this way as it defeats the purpose of folder watching.
dynosire
When you save your Batch Job, put a check in the "Ignore errors" checkbox. Errors will be logged but you won't be bothered with popup windows during sync
gorkatjimmies
That fixed the issue.
