error during mirror job
sjbrowser
Anyone ever see an error like this:
9:01:42 PM Error Cannot copy file
"L:\downloads\utilities\Systools PST Viewer\Outlook Recovery tool\storage folder\recovered pst files\file.PST.pst" to
"M:\downloads\utilities\Systools PST Viewer\Outlook Recovery tool\storage folder\recovered pst files\file.PST~63f9.ffs_tmp".
ERROR_NO_SUCH_DEVICE: A device which does not exist was specified. [CopyFileEx]
Just trying to sync (MIRROR setting) the entire L drive to the M drive. But 5 or 6 files like the above one error out. 95% of the rest of the files in the job sync just fine. The job used to complete 100% each night (for the past month or so). Then suddenly the last couple of days I get that error on those files. Not sure what to do next. Could it be that those select files are "corrupt"? I mean, does FFS even CARE about whether a file is corrupt or not? Doesn't it just copy the whole file? It doesn't run a chkdsk or the like on any files, does it?
Any ideas would be most appreciated.
thank you,
SJ
sjbrowser
Can anyone help here?
SJ
Gianni1962
Try once with your antivirus disabled.
What are the locations?
