Syncing only PDF files from one place to another
ark4diusz
I have the data on my hard drive (about 500 GB of data) with different file types. I would like to synchronize only the PDF files, which are on this hard drive (excluding any other file type) to the another location. Is there any fast way to achieve this?
Best,
Arek
Use the inclusion filter. Remove "*" and add *.pdf"
ark4diusz
thank you very much for suggestion. Unfortunately it doesn't work or I am doing someting wrong? Pictures attached.
Leave exclude empty, that is excluding everything, causing the include filter to be meaningless. It doesn't interpret that as exclude everything except PDFs, it simply sees it as exclude everything
