when i run ffs_batch, windows goes into sleep mode
giodfz@gmail.com
I'm a new user of FreeFileSync and I have a big problem:
I connected two notebooks on the home network (one with windows 10 and the other with win 7) and an external memory (usb connected to the win 7 one). I would like to use the .FFS_batch batch files to update some folders from PCWin10 to PCwin7 and then from PCwin7 to external memory, but when I go to run the .FFS_batch files, windows goes into block mode, and this on both notebooks (I use different files on the respective machines).
Why does this happen?
I hope I have been able to explain the problem well,
thanks to those who want to answer,
Giovanni
giodfz@gmail.com
Ok, sorry
I realized what my mistake was.
Thanks anyway
Did you have a post-sync command to shutdown?
giodfz@gmail.com
Did you have a post-sync command to shutdown? xCSxXenon, 23 Mar 2021, 14:59
Yes, and I didn't see it 😅
