WIN10 + Windows Scheduled Task
soontai
If you can not run in WIN10 Windows Scheduled Task
mode1: windows login is no password.
security options
1.When running the task, use the fllowing user account:
your pc user name (do not modify)
2.choice Run only when user is logged on
(if you must choice Run when user is logged on or not, recommand set your login password)
3.OK
mode2: windows login is set Password.
security options
your pc user name or modify to SYSTEM (if set SYSTEM must login username/password)
(I recommand not modify)
2.choice Run when user is logged on or not
3.select Run with highest privileges
4.input your login password and save
5.OK
The above is my current test can be executed correctly.
Because windows10 emphasizes user security policy. do not recommand empty password.
p.s My english is poor, Hope you can understand.
