hello
I can't synchronize D: folder to E: disk, it keep trying to first copy files to C: but it's huge files so no space
copy is in 'mirror mode', delete mode in 'permanent', 'fail-safe copy' option off, 'detect moved files' off
thank you for your help
Can't copy from D to E / disk C full
It doesn't copy anything to C:\ in that setup
I agree it should not :)
it's last update of ffs, restarted many times... may I report bug ?
here is picture, I could also upload settings or any information needed if any private way
That picture is not clear enough to read anything.\
What four paths are you using?
I apologize, I was trying again in different ways and found I miss a ] in destination folder, it's ok now
([diskname\folder instead of [diskname]\folder), I will buy better eyes
thank you for your time and help
Glad you got it figured out!
