I want to find files which are in both selected directory.
Is it possible to configure the listed files to view only:
1. the files which are in both directories? -> if possible to delete the files in one directory
2. the missing files in the defined directory?
How to configure the listed files?
1) Yes, you can use the filters at the bottom-middle of the comparison to show what items to display/hide. You can select all the are equal on both sides, then change the sync option to delete from one or the other.
2) Same as above, but a different filter box
