Is there an updated converter program to convert 4.5 scripts to 4.6? I know is
a small change but I have many FFS scripts to convert and a converter would be
easier than through the interface. I know there was on back in 3.17.
Converter
In 3.17 the GUI migration step would lose data due to structural changes,
therefore a converter was needed. In 4.6 the GUI approach is safe, it adapts
two xml values: 1. set command after sync to blank, 2. convert xml node
"silent" to "showProgress"
Yes but if you have a large number of configs to convert it can be time
consuming. Some kind of batch convert would be nice. Is there a way?
No, the only existing conversion is via GUI. I figure the main nuisance is
batch dialog automatically closing after saving config. Maybe unding this
"optimization" solves the problem.
