Cannot read file attributes of "\\computer\Data".
ERROR_FILE_NOT_FOUND: The system cannot find the file specified. [FindFirstFile]
if I use "\\computer\Data\subfolder". it works something in an upgrade has changed in either MS server 2019, ms win 10 or freefilesync.
any help narrowing the new feature down would be appreciated
Kevin
Lost Folders
Can you "browser" to \\computer\Data using Windows Explorer (or similar)?
Or even a, DIR \\computer\Data.
Normal acces is available in RW by any allowed, in either local or RDP modes nothing appears to be restricted in any other program tried except for freefilesync which up untill now has been functioning brilliantly
Next thought...
Error says "file".
So maybe it's not actually an issue with the "directory" (\\computer\Data), but rather a (particular) file within the directory?
Error says "file".
I have scabbed over 980,000 files looking for errors scanned drives buit found nothing. selecting \\computer\Data junst not working on mutiple requests
but doing each \\computer\Data\subfolder individualy works
