Altered view
boerakos
Hi
My display somehow changed from a single line per file to large icons, and I don't know how to change it back. I am using v10.14.
In FFS, did you try Tools/Reset Layout?
boerakos
Tried now as suggested, no change though... Thank you
therube
If you right click in the heading of the left or right FFS Compare Result window, you can select to show (or not) file-icons (note that the Folder-icons are always shown) and if icons should be small, medium or large.
boerakos
Yes, THANK YOU !!
That fixed it.
GB
