One solution for FFS freezing when syncing through MTP to Android storage
ToneM
I've been wrestling with syncing through MTP to several phones over the years.
Whenever I ran a sync to my Android mobile phone storage through MTP, FFS just froze for ages. I tried leaving it for a long while, as others suggested. That didn't work - it'd throw a few files across then freeze and lose the MTP connection.
Finally, I've sussed it. FFS gets stuck on .nomedia files.
I had accumulated 11 .nomedia files scattered throughout my music library. I've now deleted them all from the local library and the phone, except for one in the library parent directory.
I now sync a subdirectory of the parent directory where the .nomedia file is. FFS now works fine and fast.
I thought I'd never get there, as I've hammered away at this problem a load of times then given up for the time being.
Hopefully, this'll work for other users hitting the same brick wall as I was.
