Suggestion: Have pop-up window not block main window
phrab
Hi: I have Windows 10 & FreeFileSync, version 11.9 [donation edition], 64-bit. When I run a sync job, the pop-up window always shows up in the middle of the main window. It would be nice if it could be made so that if I drag it down lower (so I can see the main window), it would pop-up lower automatically the next time I ran a sync job, so as to not block it.
Also, I've noticed that if I move the mouse to any of the 4 edges of the pop-up, although the mouse turns into an arrow pointing in opposite directions (the way you expect to be able to make the window smaller or larger by dragging), it doesn't allow me to change the size of the window.
I've attached an image to show what I mean.
