Hello everybody.
As far as I understand, "Run command" property in "Syncronization settings" is used to run the specified command on the local machine. Am I right?
Is there a way to run a command on the remote machine after sync?
Or maybe there is another solution for my case: I have to change user:group for files which was syncronized.
I could solve it using chown && chown commands.
Thank you.
UPD: Is there an option to force FreeFileSync to leave unchanged the current ornwer:group of the file on the remote machine?
Run remote command after sync
