Warning after using the %TimeStamp% macro
Krodo
I use an destination path like \\server\...\%TimeStamp%. This every time causes a warning in the log because this path doesn't exist at the start of FFS. I think this warning should not appear in the log - when I use this macro in a versioning path there appears no warning in the log.
Any reference to a not (yet) existing destination base location gives rise to this notification, whether this not (yet) existing base location is referred to directly or via a macro.
This makes sense, as the user may have unintentionally selected an incorrect destination.
However, if that warning bothers you, you can opt to not show the warning anymore.
For Versioning, depending on the selected method, the creation of not yet existing directories is standard behavior, and hence no warning.
