The following items have unresolved conflicts and will not be synchronized
magictrick
I am getting the above message for a one-way update backup.
Can you confirm for me, does this mean the whole folder pair is skipped or just the individual failing items?
Mike Webb
magictrick
I am getting the message "The following items have unresolved conflicts and will not be synchronized" for a one-way update backup.
Are you able to confirm for me, does this mean that the whole folder pair is skipped or just the individual failing items?
Thanks in advance
Mike Webb
It is only per line
magictrick
So the rest of the files in this folder pair are being synchronised (and backed-up if needed ) correctly?
Yes
To add, that conflict usually only happens if the file has changed in both the destination and source since the last time you ran the sync
