Can you upgrade the Donation Edition ?
marcurling
Hello, canyou upgrade a Donation edition and how (to set up back your key)?
Thanks in advance, Marc.
The donation edition is the highest version available. What are you wanting to do?
marcurling
I do have FFS Donation edition 10.17 and wish to know if and how I can use my key to make the free FFS 11.10 a Donation edition.
If you have an active (no-expired) Donation Edition,
in FFS you can go to Help / About and select to "Check for updates now" manually,
or even to automatically check for updates once a week.
Or you can use the link provided in the E-mail you received after making the donation,
and download your latest version of the Donation Edition.
^ Correct
Whatever version is the most recent at the time of your donation period is the latest you can get
