I am running Windows 10 and have Installed FreeFileSync(FFS) version 11.11.
I am a new User to FFS and really like the product. Thank you to all. I am working through the tutorials and have an issue with RealTimeSync which is failing with Exit code 2.
The RealTimeSync parms have been created, via drag and drop, from the BATCH job parms into the RealTimeSync process. The command line parms are; "C:\Program Files\FreeFileSync\FreeFileSync.exe" "C:\Users\johnm\Desktop\Batchjob of Backup of JohnM User.ffs_batch".
I have retried the RealTimeSync process with same result.
The BATCH job that copies the same files from my C: drive to an external drive works ok with no issues.
Any thoughts on how to overcome?
Many thanks for your time and support.
RealTimeSync - Failing with Exit Code 2
