Win 10 Pro - Can't sync to a network share (FFS 11.11)
csousa2805@gmail.com
I'm trying to sync 2 folders, a local one to a network share but FFS can't access network share. I do not use drive letter but UNC instead (\\hostname\sharename).
What's wrong ? How can I fix it ?
Many thanks for your help.
> ... FFS can't access network share ...
Pretty vague!
What message do you get ("can not resolve...", "can not reach ..", "access denied")
Assuming Windows, can you access the share via Windows Explorer by entering \\hostname\sharename in the address bar?
Have you tried using \\hostIP\sharename instead?
Have you stored the correct user/password credentials for \\hostname or \\hostnIP in the Credential Manager?
Thanks fou your prompt reply.
Yes, I can access the share via Windows Explorer by entering \\hostname\sharename in the address bar.
Yes, I've tried using \\hostIP\sharename with no success.
I have the correct user/passwd credentials in Credential Manager.
I get the following error:
It's in portuguese but said: "can't find the following folder \\Administrativo\saftadmin" (it's mapped and works ok)
The error message also says: "Can't read file attributes \\Administrativo\saftadmin
