I've updated to 11.11. After some problems I decided to start some sessions from scratch and the behavior is not correct.
I make the backup of many files in a folder. Then I try a new comparison. I know there are few changes but it wants to redo all the backups.
Does someone have the same problem? Do you know how to fix it?
Thanks.
11.11 not really synchronizing
I have similar issue (viewtopic.php?f=8&t=8557) but for me it only happens when MTP devices is part of the sync pair. Doesn't happen if I sync to regular external devices (usb flash or external hdd).
I've tried with a local directory. It's OK you're right.
Let's hope it will be corrected in the next version...
Right. It worked.
