Verify with a full file compare after synchronize
kepsux
I have looked around and searched and not found a clear answer, apologies if it's something simple I've missed. Is there a way for FreeFileSync (MacOS) to synchronize files and then automatically on it's own also run a full file compare to verify the data copied properly? I do it manually now, but since both processes take a while it'd be nice to hit one button and come back an hour later and have both actions finished.
Thanks!!
therube
See: Expert Settings, VerifyCopiedFiles.
Also, External Applications might be of interest.
kepsux
Wonderful! Thank you so much!!
