Using FreeFileSync 4.3 and 4.4, there is an error when trying to synchronize
one local folder with a Samba shared folder.
The reported error is:
Error traversing directory:
"y:\abcd\"
Windows Error Code 50: The request is not supported.
Note that I am using Windows 7 (32bit) and the file sharing is using Samba.
Moreover, FreeFileSync 4.2 was working correctly.
Thanks and regards,
Milaa
Error traversing directory: Error Code 50
Opening a single bug tracker item is sufficient (and preferred).
[404, Invalid URL: https://sourceforge.net/tracker/?func=detail&atid=1093080&aid=3441452&group_id=234430]
I also encountered exact same problem on ver.4.4 using Windows7 (x64) and
Samba on Debian squeeze.
It works fine by ver. 4.2 on this environment. So I now have to use the one
downgraded to ver.4.2.
I think it is caused by some changes inserted between 4.2 to 4.4.
Thanks!
Nob
Thanks!
Nob
Sorry, I overlooked Zenju's reply!
It is working fine now using updated dll files.
Thank you very much!
Nob
Nob
