when I create a new task, I first compare the files then synchronize them. After that a new comparison tells everything has to be copied again as if nothing has been done but when I look in the folder all the files are there.
Is there an option that could explain this problem?
Thanks.
Comparison is faulty
Must be a 11.11 version bug. I've encountered it along with another user.
No issues here, what does it detect as the reason for syncing?
