File Size Exclusion not covered correctly
freesyncer
Dear Team,
I have the following filtering setup - see attached.
And even though, I have a max file size of 16 MB set, it still wants to move the 800gb file over to the FTP.
Thanks for looking at this issue.
Mike
I think those are exclude filters, so try setting the minimum size to 800gb+
justinhow
I am looking at this old thread as I have a similar problem (see viewtopic.php?t=10095) with files being copied that are above the Maximum File size set in the UI. See thread linked above for more details on this as it is not quite this straightforward.
I am not sure what the thinking is about "so try setting the minimum size to 800gb+" as surely this would mean only files above 800GB would be copied - not what the Op wanted.
I think those are exclude filters, xCSxXenon, 05 Jul 2021, 14:56
This was the important part. OP never responded so who knows
