Batch recycle bin warning
How to suppress recycle bin warning from batch?
Check 'Ignore Errors' when you 'save as' batch job. But what warning are you even getting? That it isn't supported? Just set deletions to permanent in the settings and save again if that is the case
Ignore Errors is checked.
Delete files permanent ist checked.
Why i get a logfile with warnings?
I only need the logfile containing the success info to verify this in my workflow.
Oh, the log will always contain what happened, you can't change that in FFS.
