New Feature.
Ventus2a
Hi.
FreeFileSync is a very nice SW.
I miss only the possibility to collapse out/in each folder.
I had used it with goodsync.
Thanks, Peter
You can expand/collapse them in the overview, bottom-left corner. I know that probably isn't exactly what you want, but that's something close
Ventus2a
Oh, yes thanks, that helps.
Peter
christiandull
This would be great.
