Greetings,
I am having a senior moment. When I installed FreeFileSync and setup my jobs, I swear there was a checkbox that said something to the fact "run as highest priority" or something.
Cannot find that checkbox so save my bacon. Need to uncheck it to try and eliminate a cannot file folder diaglog that occurs when job is run from task scheduler. It copying to a NAS attached to network.
Thanks.
Having senior moment with run with highest priorty
There is FFS, RunWithBackgroundPriority.
Additionally, you may have set priorities in Windows Task Scheduler or via the desktop shortcut (Properties)...
What you're probably running into is what xCSxXenon mentioned in your other thread.
