ffs backup
New user of ffs and have a question in regards backing up the configuration of this software. I have set up a number of files to compare and synchronize and would like to save the configuration in case a problem arises in the future. My question is where does ffs keep its config files so I can back up these files?
look at the path, when you "save as" your config ! And you can change it, as every software.
For the FFS sync configurations you already saved, you can search for *.ffs_gui or *.ffs_batch to find their present location.
Thank you, that's the information I needed.
