sync.ffs_lock
Ventus2a
Hi.
Can I use another local folder for sync.ffs_lock?
I sync my local OnDrive folder. The sync.ffs_lock is always uploaded to OnDrive.
Thanks, Peter
If you sync your local OneDrive folder with FFS, the sync.ffs_lock file is (temporarily) placed in your OneDrive folder by FFS; it is not "uploaded".
On the purpose of sync.ffs_lock files and how to possibly avoid them, see the LockDirectoriesDuringSync section of the FFS Expert Settings Manual page.
I also do this and it is not a problem. The file gets deleted as soon as the sync finishes
Ventus2a
Hi, thanks.
Yes, OnDrive uploads an delete the file always.
In my case I can disable this with LockDirectoriesDuringSync = FALSE
Thanks, Peter
