Example:
Cannot read file attributes of "/Volumes/MacBook Pro HD/…/config_EFI_20200525-18h48-idem précédent avec Patches ≠.plist".
ENOENT: No such file or directory [lstat]
FreeFileSync on macOS gives error with folders and files containing the character ≠ in their name
(I'll just note that FFS on Windows doesn't look to have any issues with not equal sign.)
Have you actually run the sync?(I'll just note that FFS on Windows doesn't look to have any issues with not equal sign.)
FFS not-equal-sign.png therube, 02 Aug 2021, 18:35
The comparison with ≠ runs fine as well on macOS.
Could be the precomposed/decomposed issue: viewtopic.php?t=5485
For information and in case it helps, the sync that failed because of the ≠ character was between two computers running macOS High Sierra 10.13.6 via the local network.
I also haven't noticed any problems so far with accented characters and other special characters, which I use routinely.
