Mirroring or Syncing for Tethered Shooting (Photograph Files)?
KevinH
Greetings!
I'm a new user on the forums and I looking for some advice.
While, I haven't downloaded the program yet I'm so happy it's open source.
So, I did a search of the forums and didn't easily find a related post.
I need a way to backup photos when I am tether shooting to the laptop.
May I also ask if I should use mirror synchronization or real time sync.
I don't want to overwrite existing files (with same name) on the right side.
Can the software change the name of the new file on the left side so it doesn't overwrite an existing file on the right side?
Sometimes my camera resets the file naming so I don't want overwrite an existing image.
But each new photoshoot I would setup a new configuration I think.
Thanks for reading this.
Be well :)
Best Regards,
Kevin H.
