Cannot See File Type .m3u8 Playlist
insiteweb
the program Cannot See File Type .m3u8 Playlist ?
Check your filters
insiteweb
yes no filters, tested and tried serval different ways, it just shows a blank folder, even when choosing the path the folder is blank.
Gianni1962
Here on Windows 10 Pro 20H2 64 bit and FFS 11.13 64 bit no problems with those file type.
Include filter:
Exclude filter:
\System Volume Information\
\$Recycle.Bin\
*\thumbs.db
\RECYCLE?\
In Windows, when choosing the path using the Browse button, it is normal to not have files listed but only folders.
therube
Looks like it, yes.
Might you have a minimum file size filter set?
.m3u is likely very small, & you may have excluded "small" files.
insiteweb
[img]when choosing the path using the Browse button, it is normal to not have files listed but only folders.
BUT it does not move files, even when update or mirror selected and it's looking at all the *.mp3 which are be excluded, see attached
insiteweb
IDK deleted and recreated twice seems to work
Image didn't show up
