single working directory mirror to multiple USB drives
gary_freefilesync
I'm using FreeFileSync v11.11.
I want to use FFS to mirror a working directory to 2 different USB devices. Will this cause problems with the sync.ffs_db files?
The mirroring operation to the 2 different USB devices will not always occur at the same time.
Regards
Nope! The db file is for the location that they are located
gary_freefilesync
Thank you for the confirmation! That's what I was thinking.
