Hello first of all I must say I have been using FreeFileSync since version 3.1
when I randomly discovered it and nowadays I think I could not work with my
computers without this program, it is simply amazing and very very useful I
hope Zenju will live 1000 years. This is my first post because until now I
never had any problem or complain.
I will try to describe my problem as clear as possible becasue Im a noob with
computers and I dont fully master english language, also I cant really
identify the cause of the problem, Im totally lost.
I work with 2 computers alternate. First I use PC1 (system with Windows 7
Ultimate x32 bits) and then I do a backup of my work in an external USB hard
disk with FFS and copy the data in PC2 (system with Win 7 Ultimate x64 bits)
and continue working there.
Then when Im finished working in PC2 I do a new backup to PC1 through the USB
HD again. My settings have always been "Compare file date and size" and
"synchronize mirror to the right" also I use the same FFS version on both
computers all the time.
Now the strange thing, I have noted FFS suddenly changed one of the folder
pairs going down one folder sublevel, all on its own, for example:
"<Left>C:\FOLDER-1\SUBFOLDER-1(????) <-----> <Right>D:\FOLDER-1\"
When originally it was FOLDER-1 on both letft and righ sides.
This started happening when I updated from FFS v3.21 to v4.0 (I manually
unistall FFS from Windows control panel and install the new FFS downloaded
from here on both computers) and like I say I didnt changed the subfolder
myself it was fortuitous.
I also think this started happening when I did the backup from PC2 the one
with Win 7 Ultimate x64 bits. FFS has administrator rights on both machines
though.
Even more weird is FFS doesnt let me correct the folder address and save the
correct route, I manually do the change and save it (FFS does the correct
synchronization then) but everytime I load FFS it is again there even when I
saved it...
Im completely lost so I will leave the problem description here to not cloud
more the problem. Maybe there is some clue about whats happening.
Thanks a lot for the help and keep the good work!
FFS selects a subfolder and cant change it
Hello again I have just discovered a new thing about this weird problem with
FFS and Im gonna post it to help identify the cause.
I have noticed the same subfolder change suddenly appears in another
configuration profile I had saved to do similar backups but in another
different external hard disk. The problem is I have not used that backup
configuration for months and that HD has been inactive all that time.
More things, I have opened with Notepad++ the ".ffs_gui" configuration files
for both profiles where the spontaneus subfolder appears (the config I use
randomly and the one not used in months) and the subfolder is not there in the
pair folder route, in the config file is correctly on both:
<Pair>
<Left>C:\FOLDER-1\</Left>
<Right>F:\FOLDER-1</Right>
Without the intrusive "\SUbFOLDER-1" which only seems to show when FFS runs
the config file...
Now I am going to try to delete that config file and make it again to see if
the rogue subfolder reappears.
Thanks again.
<Pair>
the config file...
Thanks again.
There is some inherent issue with using wxComboBox, that was triggered by some
more or less unrelated changes in v4.0.
More details and a fixed version can be found here:
[404, Invalid URL: https://sourceforge.net/tracker/?func=detail&atid=1093081&aid=3415437&group_id=234430]
Thanks for the fast response, yes I read that post before while searching for
info about this problem and was thinking it was somehow related to it but
since I dont have much idea about these issues I decided to write a help post
just in case.
For the records I deleted the config files, made them new and the rogue folder
showed again.
Thanks again for the help and excuse the wall of text, all I can say is I
still have much to learn about this awesome program.
Best regards.
just in case.
showed again.
Best regards.
